Ive sold my half leather seat to someone who wants them for vw camper the problem i have when i took them out i leaned them forward by the electrics now there out the backs lean forward is there any way i can ajust them without taking my new seats out and putting these back in just to just plug them back in as the cars winterized and with the weather as it is now didnt want to take cover off roof down ect
The main connector under each seat is at the end of a long enough wire that you can unplug it and then plug it into the seat that is already out of the car. You can just put the seat right next to driver's (or passenger's door), and it might be even easier if you set it on a milk crate or similar support.
You might want to clip on a wire to the frame of the seat and run it to one of the ground points on the floorpan.
Be careful that you set off the airbag light (unless you have a Durametric, PST2 or PIWIS available).
Regards, Maurice.
All sorted easy really didnt want to risk setting off airbag light so just used a battery booster disconnected white 2 pin plug and used 2 wires from booster into white plug
