No they will not work. The Cayenne has two sumps(V8's) that need to be drained and you'll never reach them using an extractor.
I plan to test this within a week (depending on when I get it back from dealer service) on my 2010 Transsyberia. The new V8's have only one drain plug.
I'll suck as much as possible out through the dip stick tube with the MityVac, and then drop the drain plug to see how much more comes out. With the oil filter located on the underside of the engine, I have to crawl under there and drop the skid plate to access the filter anyway.
As an aside, you can change the oil and filter on all new MB engines in your Sunday best; and not get dirty. The oil filter is on the top; and when you loosen the canister, all the oild drains back into the block in down to the oil pan. All oil can be sucked out the dip stick tube with the MityVac. Complete oil and filter change with clean clothes!
Edited by DUTCH VanAtlanta
I am a proponent of changing your engine oil the old fashioned way - get the car good and hot and then drain the oil through the drain plug.
I change my oil at roughly half of what the manufacturer recommends. Why? Read the reports on sludge build up in modern engines. It does not take much moisture and contaminates to cause engine oil congeal (and gel) - that means "sludge" or an inability for the oil to flow to small passages in the engine where it is needed. As several articles say if you bought a used car and the previous owner(s) did not change the oil per the manufacturers recommendation then you could have the hidden problem of sludge.
Here is an example article about sludge in modern engines and class action lawsuits - many manufactures involved. If you Google engine sludge you will find many many more.
New York Times Article
My goal is not to waste money but to not allow the sludge to form - so I change my oil early in the maintenance cycle. Seems like cheap insurance to me. JMHO of course.
Agreed, except I would get it good and hot; and suck it out through the dipstick tube on MB engines. Experience on two different MB engines showed I got more out with the MityVac than I did with a drain through the plug; and if you do it while it's hot, you'll have the crap well suspended and removed, too.
The Transsy will get its oil & filter changed for the first time at just less than 2,500 miles. I would have preferred between 1,000-1,500 miles, since lots of crap comes loose during break-in; but the timing just couldn't be worked out. Then at 5,000 miles and every 5,000 miles thereafter - always with Redline synthetic, since I'm not a big fan of Mobil 1. Overkill? Possibly, but very cheap insurance.
I used a MityVac on my Transsyberia (GTS DFI V8) yesterday, and was able to pull about 8 qts. That left only about 1 qt in the oil pan for much easier draining.
Since the bottom protective cover needs to be removed ti get at the filter, you might just as well get that last qt out of the pan through the drain plug, too. However, handling 1 qt in a small drain pan while laying under the car is a whole lot easier than having to maneuver a big drain pan with 9 qts sloshing around in it. :jump:
See here for specifics on the oil change:
http://www.renntech.org/forums/index.php?s...mp;#entry163791
