Hi
I am in the UK
I have a 1998 Boxster 986 I( have just fitted an HID conversion kit to the main beams. I already have Litronic dip beams.
The headlights are now awesome BUT when I put the main beams (high beams) on all the warning lights flash and the clock goes to 1 am and the trip meter zeros
Any ideas anyone please with a how and where to get please
Many thanks
Dave
PS If I leave it alone and live with it will it do any damage to the ecu ?
It sounds like a voltage spike. Is everything properly grounded and the ballast isolated?
Hi James
Thanks for reply. I have fitted it exactly as per instructions
It does not mention earthing the Ballast
This is just fixed behind the headlight but on plastic?
Regards Dave
Sounds faulty to me Dave - I have an '01 and have just done the same. If I'm super-critical, I get added interference on FM when on, but that's it.
Cheers
Cheers
Hi
I have been investigating this and apparently it is common
Depends on something in the ballast
There is a 'warning eliminator' on the market for about £12 I will try
Dave
I thought that would only work with post '03 cars with far more fancy electronics?
Hi
I spoke to them on the phone and gave them the year of the car and they say it will work
I will let you know if it works when I fit them
Dave
Hi
Dave
No they did not work
When I fitted the Kanbuss Killer the headlights stopped working completely
Removed and all working but still have the fault
The guy is going to try to help me after Christmas
UPDATE
A company is selling me 2 new Ballasts for £50 from a complete kit designed for the Boxster 96 - 04
Apparently they have a chip inside which fools the computer into 'seeing' Hallogen bulbs
Lets see if this works
I will keep you posted
Dave
  • 2 months later...
OK finally sorted
Got another kit on UK E Bay
item no 270490919248 - VISIONDP - £72 inc uk postage - guarenteed to work - all works fine
E Bay shop - VD lighting and performance - visiondp@live.com
6000k bulbs
Sent all the other kits and bits back for refund
Dave
Edited by aviator at elstree
