Hello !
I have a Boxster S 08´ I have recentley noticed an issue
with the driverside window not sealing corrcetly against the seal
with window and top Closed...there is obviusly wind coming from
there while driving the car at normal speeds.
I assume that this is adjustable ?
Is there anyone here that have this issue and maybe a´ DIY solution ?
I suppose this is a warranty fix ?
Thank´s / Best Regards !
Hello !
That is a warranty fix. There is an adjustment that can be made without removing the door panel. It involves accessing the torx screw that acts on the clamp supporting the window glass, one if front, one at the rear. The access is from underneath the door, by removing two of the four rubber plugs that you will find under there.
Do a search here for a post that shows the arrangement of the plugs and which ones to remove, with photos, etc...
Regards, Maurice.
Hello !
Regards, Maurice.
Ok,Thank you very much that was a very quick and good answer !
I will take it to the dealer while it´s under warranty,this is a problem they
should fix pretty easy then dont you think...
Is there any good advise regarding the lubricating / maintanance
of the mechanical movemenst of the top ?
Or vill the every other year service at the porsche dealer take care of it ?
I am taking very godd care of the car in regards to the paintwork and the oil filter stuff..
Thanks / Best Regards
