Hello everyone,
I want to install a rear strut brace on my 2002 Porsche 996 C2.
Can anyone give me some help please?
Thanks.
Why? might I ask...
Short of going to a full weld-in roll-cage, with pickups at
the suspension points, I'm not sure there is any
real benefit to the typical "strut brace" here.
The 911 monocoque chassis is pretty stiff, and rear
multi-link suspension practically eliminates the need
for such an add-on - rear shocks do connect vertical
loads to the chassis, but lateral stresses are handled by
the subframe and upper links.
The typical performance upgrade is to replace the
(rubber bushing) stock toe and upper links with
spherical links ("dog bones"). However, I believe this
is really only suitable for track use - Porsche designed
in the mechanical compliance to provide a stabilizing
rear toe-steer effect under lateral loading, and provide
some compliance for ride comfort. So buyer beware,
if you choose to go this route!
If you still want to, check out GMG Racing, etc. They have
the shiny racecar spherical-jointed links that so many
find sexy.
- Sanjeev
