Hello
My Car Is carrera 997.2 2009
If i disabled the electrical wing buy delar computer. witch brake light should be working, the on the wing or the one on the higest body.
Edited by maximumboost
I would expect that whichever one works when the wing is down normally would continue to work.
Why would you disable the wing?
Hello
Thanks for your answering Loren, i disabled it becouse i buy a wing without a brake light and when i desabled the wing the hight brake light not working. only if i fixing the brake light from the original wing its work.
In most cases on the previous model if you switch to a fixed wing then you needed to change the small wing wiring harness to the same harness the Aerokit (fixed wing) uses.
If you are switching to a Porsche fixed wing then the harness and or any programming should be included.
Thank You Loren
