Hi Gang
I've got an unusual and annoying problem. The passenger door is making a clicking sound. It sounds like an actuator (solenoid) going on and off. Similar to the door lock sound but much quieter.
The window seems to work normally, the door lock as well.
I hooked the car up to my Durametric cable and did not get an error code.
Any thought what this might be?
The Car is a 2000 Base Model
  • 9 years later...
Mine made such a noise when the window regulator was about to die.   But only when using the up down.    FWIW.  Can or cabriolet?   Could be trying to reseal the window?   Not much else in there
I’ve done further research, and found that the motor that controls the automatic fan zone selection for the comfort control can sometimes get stuck.  I turned on the fans to high speed, blew out some foam that had deteriorated, and the problem went away.  It’s a 99 Boxster base.
