This morning I jacked up the car to block it up for the winter. Came out later and there's a small puddle of oil and find it came from the left rear engine mount. I did jack up the rear by placing the jack under the engine knob jack point. Did I cause this problem by using the wrong procedure?
Oh dear... not this again. Yes the mount has been damaged and replace them in pairs. Search the site and you'll find post on this subject.
Yes, the mount finally failed, which means the other one is not far off from failing too. Just get a new pair and either install them your self of have someone do it. You did nothing wrong, Fluid filled mounts just fail over time. It seems to be inherent in the design, no matter if you have a Porsche, Audi, MB, or BMW. They all fail.
wvicary, it seems that when I have something screwed up, I learn from you. Thanks
Orient Express, I was feeling pretty stupid about this. I thought I did caused it. Our car is a 2000 Cab Arena Red thats not quite up to yours. Ive noticed yours on here before and thought it looked pretty sharp. Thanks
Motor mount replacement for a 9 year old car is not that unusual. You are fortunate that they failed in a way that you were able to see it rather than they fail on the road, and you go for many miles on bad mounts.
These mounts just fail with age but I never recommend lifting the vehicle using the engine. I'm not trying to start another war about what is the best way to lift your car... just offering my opinion.
Does anyone have a good write up on how to replace the engine mounts?
1. Place floor jack under engine and lift it up to support engine. Don't lift the engine or car, just hold the engine in place.
2. Remove engine airbox and secondary air pump for access to rear motor mounts.
3. Making sure that the jack has the engine supported, remove the nuts on the lower end of the motor mount that holds it to the engine rear crossmember.
4. On the top of each motor mount, remove the 2 bolts holding it to the chassis. Lift the old motor mount out of the chassis.
5. Install new motor mounts, bolt the mount to the chassis first, then install the lower nut and torque it to 67 ft/lb.
6. Remove floor jack.
Done.
Done.
Thank you mate. That will help out and it looks very simple to do.
Unless you get solid mounts, you can expect to have any liquid filled mount to fail at between 60 ~ 120K miles.
What would be the best option then? I don't want the viberations to come back for a long time as I plan on keeping the car for a good amount of time.
Just replace your existing mounts with new fluid filled ones. Solid mounts are going to transmit all of the engine vibration into the car.
As a matter of general maintenance, I budget for motor mount replacement on any car I have that has more than 75K miles.
That was a stupid question on my part about the solid motor mounts I didn't even think about it. Thanks for you information. Has anyone used the ones from ebay they are suppose to be OEM but not OE. For the price of one at my local dealer source with my shop discount I can get the set on ebay. I don't know if it's worth it. The job isn't hard to do unlike the ones on the 944 types which were a pain.
I found the those mounts cheaper at a Porsche online parts provider:
http://www.egermanparts.com/
