I'm planning on replacing the air inlet grilles on the front bumper this winter. Do I need to remove the bumper or are these accessed from below once the belly pan attached to the bumper is removed. How are the attached, snap fittings or screwed in from behind? Car is a 04, 40th anniv so it has the C4S type front bumper.
Removing the front nose will make the job much easier. DO a search for nose removal or readiator cleaning and there will be DYI instructions to remove the nose. I have done it several times and it an easy job ( but easier with two people).
Good luck!! demosan :cheers:
Found the directions & video. Looks like an easy 2 - 6 beer project.
if interested I make a stainless (handsome) grille insert for the front air intakes on GT3 and RS
