Where is the steering fluid resovoir located and what brand and type of steering fluid to use? Also, can steering fluid be bought at stores such as: Autozone, Shucks, NAPA, or CARQUEST? Thanks for feedbacks to assist me with this.
The PS reservoir is in the engine compartment on the drivers side, up close to the firewall. Once you get the convert. top into service position, you can remove the engine covers and you can't miss it. It's a twist cap, and has a dip stick in it. You can top it off from there.
The factory fill is Pentosin CHF11S usually, but that fluid was superceded with CHF-202, whcih can be used to top off an 11S system w/o issue. I have not been able to find it anywhere like Autozone, etc. I got mine at the local dealer, and didn't get overly charged (shockingly). I tried to get it at Napa, but my local one told me they didn't store-stock it, and since it wasn't all that common, i'd have to buy an entire case for them to get it for me. lol :)
Keep in mind it comes in 1 quart metal cans, and under most driving, to "top it off" only takes a little bit. That can will last you a LONG time unless you track the car or have a leak.
Bill
Thank you so much!
Bill
Thank you so much!
Bill
FYI - I have found some NAPAs that do stock it in the store.
