I have a porsche rep wheel that im trying to fit. i took care of the fronts. The rear tire is 19x11 with a 58mm offset. What size spacer will i need? I want to keep it as close to the shock as possible to eliminate too much poke.
I fit these same wheels on a boxster with a 23mm spacer in the rear.
