OK, 2002 996TT... The little tether on my gas cap broke a few months ago and I've gotten a new unit, ready to install. How in the heck do you get the little grommet holding the original tether out??? I can get it about 2mm, but how in the world do I get it to release so I can get the new tether and cap in there??? Thanks guys :renntech:
since you're a contributing member, down load the TSB for the Aluminum Look fuel cap. Has all teh details and parts if needed.
Dan
Simple. Just use something to carefully push the center pin through all the way. Pull out the rivet and you're done...
