I have the out side temperature indicator giving me wrong readings (off by 30-35 degrees). When it is 28 or 30 degrees Celsius outside, it shows -4 - 0!!. It is affecting the AC work in auto mode. So instead of giving a cool air it gives heat.
Is there a way to reset the sensor through Durametric?
Some times after a car wash it even gives temp of -4, when it is 25 out side.
There is no check engine light also.
What should I do?
BTW we are talking about '99 C2.
Any help is appreciated.
thanks in advance for any contribution
Edited by porsche911
Model and year of your car please?
Check to see if the sensor in the front bumper is damaged or has a loose connection.
thnx for the reply.
it is C2 '99.
thnx again
