Hello, Help dead battery, trunk will not release. It's in the garage not much room to get around. Can't get into trunk to charge battery. Help. Car doesn't have the hood release in fuse box.
1/ Opening the plastic arch at front inside one of the front wheels location ( right or left depending model year ), you will find a secret manual cable in order to open the trunk :P
or
2/ Inside the fuse box at left of driver legs, you will find a dedicated button to pull and to use as + of any charger ( - on car itself) :)
or
3/ As said having a porsche charger to fit with the cigare lighter in the middle box ;)
