Read over on the pelican forum that a swap of a 3.4L into a 2.5L was
electrically the same.
I thought the 3.4L used a 7.2DME and had the wiring harness of a 7.2DME
thanks,
mike
Thank you,
Follow on question....
Is the cable from the IMMOB to the DME as well as to the front of the cabin
the same for all models?
So if I had a 7.2 DME that I could somehow clone the security code to say a 5.2.2 DME,
could I then just swap the 7.2 DME for the 5.2.2 DME and have it work properly with a 7.2DME
engine? How about a 7.8 DME/engine.
I'm trying to find a cheap Test Sled and 5.5.2 boxsters can be had very reasonably.
I already have 7.2 and a 7.8 DMEs.
thanks,
Mike
