That rubber trim wraps around and down under door. It is all one piece.
There is a clip behind the inside door panel that fastens the top rubber piece (near the door handle). Then you can carefully pry out the bottom from the clips that hold it in place.
Do I have to remove the door panel and the window to replace? Also whats the part number on the rubber trim. Thank you.
Window - no, door panel - yes at least the top corner near the clip.
996 537 085 07 Left Outer Gasket
996 537 086 07 Right Outer Gasket
My price list is about 1 year old and it shows a retail price of $256.76 each.
