Hello,
New owner here of MY02 Carrera. Loving it! Coming from the BMW world where I knew all the tricks and now i'm starting from the bottom with the Porsche. I'm trying to figure out how to get both of my keys to work for the remote lock/unlock. I've searched but not seen a situation listed like mine...
1. Both keys start the car properly.
2. Red key (red at the top of the blade) works in the ignition and properly for lock/unlock.
3. Yellow key (yellow bit at the top of the blade) works in the ignition but does nothing for lock/unlock. I don't get a lit red LED on the key when pushing the buttons either.
I would like to reset the one (yellow) key so they both work without somehow disabling both keys and screwing myself. I have no idea where to start and I have searched many posts and googled but only return things like "see the dealer" which is OK for most, but I personally like to know how everything works. (Unless that is my only option...but I would hope I could recover the functionality since it is not a new key.
Thanks. :D
Have you checked the battery in the key? It sounds like it needs replacing.
Edited by GoBruins
Welcome aboard. You will find this site provides the BEST technical support..period.
You have the following options:
1. try a soft reset...this is done by inserting the battery reverse polarity for about 10 seconds and then installing it correctly
2. A new battery (as stated above)
3. "Wake" the key fob...insert in the door and unlock the car then hit the remote button...this happens if the key fob has not been used for 5 days
4. reprogram...this needs a Porsche tool (PIWIS or PST2)
5. New key (and reprogram)...most $
I have heard that if you don't use the key for >6 months it needs to be reset, but I have never tried this (I always use both keys at least once every 3 months)
Edited by wross996TT
I recently had a similar problem with my 02. Replaced the batteries and they worked for a couple more weeks, but alas, had to replace them. It costs $230 at the dealer to replace the circuit boards on both keys, but at least I won't have to deal w/ key probs for a while...
