Looked at Advanced and AutoZone problem is the one bulb that looks like exact match has different pins. The rear fog bulb has an offset pin while the others that looked like a match are not.
  • 3 years later...
I replaced both backup light, the fuse is good, but reverse light are not working and still get warning message. Do you have any diagram or where the switch is located. Thanks.
There isn't really a switch dedicated as reverse light switch but the circuit is controlled by a module.
