Will be doing an LED DRL mod shortly, but was wondering if there is a switched supply in the front trunk area I can tap into?
Cheers
  • 4 weeks later...
I added LED running light over the summer, and I took apart most of the trunk looking for a switched power source in the front, I couldn't find one. I just used the switched power source under the center console, at first I didn't want to run a wire through the firewall but it turned out to be very easy. Good Luck!
Edited by rick3000
