Hello there guys...My best friends 996TT from time to time refuses to start without pressing the throttle...When i plugged my PIWIS i read P0012 (camshaft position with respect to crankshaft bank 1) and P1349 (camshaft adjustment bank1) codes...Could it be just the sensor of the bank 1 set of camshafts?Any ideas?Car is running fine otherwise...just rarely a little rough idle last days when codes occured...
P0012/1349:
Possible fault cause
♦ Solenoid hydraulic valve camshaft adjustment faulty
♦ Allocation of camshaft to inlet camshaft incorrect
♦ Dirt in system
♦ Solenoid hydraulic valve mechanically blocked
reset it and see if it comes back....
Thank you guys...i did a reset but it comes again...(there is no cel just the car wont start easy from time to time...)
The you need to fix the cause...see my previous post. Do you need more info?
