Hello all,
I recently purchased my first Porsche 993 series C4 from a local dealer and noticed the ABS warning light comes on sometimes. They took the car back and looked it over but found no faults. Could the ABS sensors be hypersensitive from sitting on the dealer's lot for a few weeks? I'm used to dealing with old english cars so ABS sensors are new to me. Anyone have experience with this?
Craig
Just a thought that someone bled the brakes and got air into the ABS. If so, it'll require bleeding with the factory "hammer" tool or using the method of bleeding while turning the ignition on which activates the ABS pump. You might check with an OBDII reader and see if it's throwing a code.
