Hi! I just installed the itronics for BT/ipod and Backup cam. Everything worked fine for a week. Yesterday, when I turn on the radio, nothing works...no sound and I get this message: system error navigation and amplifier not detected. Is this a problem with the itronics install, dead battery?
Help please
Ian
1 - find and pull the fuse to the itronics unit then replace it
2 - do you still have a changer on the system
Help please
Ian
Hi!
The installer switch to another fuse (constant 12V) to provide power to the itronics. It seems to work for a week. My Porsche cayenne doesn't come with the CD changer in the rear.
It's very strange, sometime, it works flawlessly and sometime nothing works (radio, nav, BT, Ipod) and I get the message "system error, navigation and amplifier not available". Sometime, after 20-30 minutes drive, everything is coming back. What's wrong? is it the fiber optic not well connected? power problem?
Should I install it in the back at the CD changer connection?
Help please
Ian
does sound a bit like fiber
mine is installed in the front ok
they may have bent the fiber
Hi!
Help please
Ian
So, if the fiber was bent from the installer, how can I prove it? should I bring back to the installer or porsche dealer for Most piwi test? can it be a loose connection somewhere? does it have anything to do with the bybass switch? I don't really what to do...
Hi!
Help please
Ian
Tough call but I would try the installer first. I mean you paid them to install it, so they should fix it. If they did bend a fiber optic, it may require dealer diagnosis.
Having just installed the itronics a couple weeks ago, it is kind of hard to pass the fiber wires to the head unit but a careful installer shouldn't of had to much of a problem. Let them check all the connections and fuses first.
ditto
I have the same problem error msg - "system error:navigation system, amplifier, CD changer, phone not available" I have removed and checked fuses, and then took to my Dubai dealer who ran the diagnostics, nothing explained to me if something came up or not as not allowed to stay with their engineers, but they did disconnect the battery to try and reboot the system and eventually they reached the conclusion that the phone module is faulty (they said this is connected in line to all the other elements so if this goes down nothing else works!) do I believe them? dont know - this Turbo 05 model uses a motorola module and they did not have one to see if this was the problem but I have to say I am dubious and wonder will they simply replace various bits of kit at great expense when it may be a simple problem somewhere. I have not changed anything simply was working one day and not the next! So if anyone can shed light on this I would be most grateful.
Regards Baz
Help please
Ian
Here is an update...Brought to the dealer, they've done some tests and found no error and the problems recurs intermittently...
Help please
Ian
reset the system press 158 @ the same time it should reset it :D
Regards Baz
Baz - I live in Dubai and own a Cayenne S '06 and experienced big problems with the Bose amplifier. Lots of noise, cracklings, explosions from the stereo system and I also had the same system error. I was told to replace the amplifier @ AED 4770 without installation and labour. Instead I bought a new amplifier from the US for AED 3,400 + AED 250 for installation and labour. works perfect now! This might be your problem
Regards P
