I just bought a 2006 Boxster 2.7 RHD (softtop) , this baby looke like a few things need to re-place. I had just re-placed the brake pads and i am wondering how to check where is the air-filter located and how to un-install ?? Need Help please advise ??
Well, first you need to get the convert. top into "service mode." I can't remember if that's in the 2006 owners manual or not. (Porsche eventually removed the steps from later model years.) If its not, you can just search here on the message board. The process is the same.
Basically, you "partly" open the top (so that it's about 6 inches from being closed, and the clam-shell cover is at an angle). You then unsnap the felt rear liner of the top from the rear retainer clips, release two small cables, and pull the top up manually until it "clicks" into place, just aft of the seats. Then you can remove the engine covers and access the air box, which on a left hand drive car is on the left side, just inside the air scoop.
The search feature on this board is really good. Just search for it here. The procedure, and even the air filter replacement has been covered many times.
