Can anyone provide instructions for front bumper cover removal on a 2005 987. The DIY instructions here on Renntech for the 986 don't work for the 987. Thanks for any help!!
The differences between 986 and 987 are: remove the front part of the wheel well liners - pull out the left and right slide fastener from the (open) trunk side, on the (small) spot where the bumper meets the fenders - the side markers can stay in place (the horizontally situated screw behind the marker is canceled) - separate only the lamp holders from the side markers - separate the headlamp washer water tube from each other on the quick release system (left side of the car) if installed - separate the electrical connector in the right radiator area - the rest should be the same as 986.
