Getting the non-smoker cubby from Suncoast.
Probably a dumb question, but what do I do with the little light that formerly sat in the ashtray? I'm assuming you can't just tuck it under, as that bulb can get a bit warm. Is it as easy as cutting the wire and capping it off?
Mike
The light just unplugs(connector underneath). Just cover the end and wire/zip tie the connector off so it does not get caught up in the e-brake mechanism.
regards
regards
Great! Thanks for the tip.
