Does somebody have a picture or a link of the removal of the front door panels? My doorpanels are wet at the bottom. Therefore I would like to check what is going on.
Regards, frank
I am going to post how to replace the micro-switch
soon. It will show you how to remove the door panels.
Look for it in the DIY section.
Paul
Edited by PAULSPEED
Thanks a lot Paul,
I removed all the screws. nonetheless, I could not remove the panel. Feels like I am missing a screw. There is play on top of the panel, but no movement at the bottom of the panel. I am afraid to ruin the panel. Any advice?
regards, frank
Aputty knife and a long screwdriver will help you pop
the trim. Look at my link above.
There are five torx bolts.
Good luck.
Paul
Edited by PAULSPEED
