I have a 1999 Carrrera with 135k miles that has developed an electrical short. When I apply the brakes hard and the ABS is activated, the horn shorts and starts to sound. You can actually hear the horn contacts activating as the ABS goes on and off. There are no warning lights on the dash and all electrics work fine otherwise. The horn works normally but does seem a little light to the touch. Any suggestion on what is wrong?
Mike
Sounds like you're hitting the brakes so hard its compressing the cover into the horn....thats pretty cool!
My guess (only a guess-I havent torn a steering wheel apart) would be that the shudder from the ABS is moving the contacts just as you think-could be a lose clip/corrosion of some kind that built up-
OT a little-how often are you engaging the ABS? I've yet to trip mine and I drive like a tard almost everywhere!
Mike
:welcome:
Not likely a short but worn horn bushings.
See the post here
