Car: 2001 Carrera Coupe, Tip
There are two plastic electrical connectors behind the battery in the front compartment. I'm not sure what they connect to...
The driver's side one has some corrosion on it (it doesn't look like battery acid corrosion, just normal corrosion of the aluminum connectors inside the plastic part). I don't know if this is causing any problem, but after I noticed it this evening I took the plastic connector apart and cleaned the electrical connections just to be sure.
Anyone know... a] what these two connectors connect to? and b] has anyone had any corrosion problems in this area? c] are there any symptoms I should be on the lookout for?
Thanks in advance,
Steve in AZ
Edited by EnglishSteve
