Supplement to 2Din unit receiver installation
In finished my installation about 1 year ago. My system is AVIC-F700BT + Alpine PDX-5. I ran into few problems when I did the installation. - Place to run the cable from the dash (interior) to the amp (front trunk): There is a small rubber piece near the dead pedal. I cut a cross to run through it. You can refer to photos. - There is a wire for receiver to send on/off signal to the amp. Use a new wire instead of using the existing wire. When I did the installation, the existing wire did
Edited by jademade
- There is a wire for receiver to send on/off signal to the amp. Use a new wire instead of using the existing wire. When I did the installation, the existing wire did not transfer enough power. I did not understand why, and it took me few weeks to realize using a new wire would be a better choice.
I never installed any car stereo before. It took me few weeks with my friend's help, but the result is rewarding.
Jade:
Thanks for posting the tip about where to run the wire near the dead pedal! I'm looking forward to installing a new amp and head unit and will probably go that route.
Regards, Maurice.
