I have been speculating that my transmission mounts are going bad. I took a look at them and was wondering what the play should be on the mounts. To test them, I wiggling the transmission with a bar. I could easily move it around with about an inch of play on each side. Is this normal, or does it seem like they need to be replaced?
If they are bad, where is a cheap place to get just the mounts without the brackets?
Thanks.
