I picked up one of the LN Engineering oil drain plugs for my Boxster, but my Cayenne needs an oil change first. See http://www.lnengineering.com/drainplug.html for details on the plug. Will this fit the Cayenne also? When I looked in the online PET, the Cayenne shows 2 drain plugs part number 900 219 020 31 and the Boxster shows one drain plug part number 900 219 009 30, but both are listed as M18x1.5 screw plugs. Are these really the same plug, or is there some difference? Does the Cayenne need 2 of these plugs?
Oil change at the dealer today as part of the 24K mile service. LN Engineering magnetic oil drain plug worked fine on my '08 Cayenne S according to the mechanic. Starting in '08, Cayenne V-8 engines only have one oil drain plug, older ones have two. Neither the mechanic nor the parts manager knew what the difference is between the Cayenne and Boxster/Carrera oil plugs. Anyone?
08 and newer Cayenne S's also use a different oil filter too. I found out the hard way!
I am pretty sure it is a different plug too. I think the 996 one is smaller.
Edited by OCNYPORSCHE
