ok guys i have a big problem
today i tryed to remove my headlight and noticed that the bolt in the little hole you put the tool in isnt there
what do i do now?
my driver side has it but not the passanger?
is there any other way to get it out?????//
any help would be greatly appreciated thanks in advance
what do i do now?
make sure you are have taken the right plug out as there are two and can be easily mistaken the one you need is the thick one that stands out.
failing that you will need to remove your wheel and wheel arch liner and manually relese the light
what do i do now?
ok so if i remove the wheel and liner how do i get the light out just push it forward? or...????????????????
what do i do now?
no there is a bracket that needs relesing 1st try to do it with pliers or a screwdriver if you take your other headlight out you will be able to get an idea of what you are dealing with and best way to relese it
