Does the tipronic computer have the same security code feature as the DME/IMMOB/FOB?
Reason I ask is that I have a car where I had an IMMOB disintegrate due to water.
For testing purposes I replaced the IMMOB and DME with a matching set from Oklahoma Foreign.
I've got the dme and Immob talking to each other but the car will not try to start
and when I use the duramatic i get a
CAN BUS Failure Tiptronic Implausible. I forgot the exact code value.
Also does the Tip Computer have to be talking to the DME/IMMOB to allow
the starter to fire -- or am I looking at multiple issues here?
thanks,
Mike
Tiptronic should work; at least mine works after replacing the dme/immob/fob-even changing from 7.2 to 7.8. Did you change anything in the wiring? Was the dme from 996 or from a manual?
Sergiu
Sergiu
No wiring changes, I don't know the source of the dme/immob/fob. I could probably extract that info via Duramatic.
Is there a way to see if the pill mates with the IMMOB other than just trying to turn over car?
I'd like to isolate my failure mechanisms.
thanks,
mike
