What tool do all y'all use to torque the rear sway bar link to the strut?
A crowfoot of some sort? Normal Snap-On style crow foot wrenches
aren't long enough to allow the torque wrench head to clear.
Bill
Problem:
You need a 17mm open end crowfoot. But normal crowfeet aren't long
enough and the head of the torque wrench doesn't clear the strut.
Solution:
I put a 17mm combination wrench on the hex of the stabilizer link, and
fitted a 17mm driver (drain plug tool) into the box end of the combination
wrench.
Keep the wrench at a 90 degree angle to the torque wrench and no correction
factor is needed.
I've attached two pictures to the msg.
Bill
