OK...latest little thing on my Cayenne S 04.
I have a problem opening the center console--the 'box' just behind the cup holders. I can open the bottom portion just fine, but when I push on the upper button to open the top portion--won't budge.
Seems to have a lot of slack. I have moved it around, pushed the button hard/soft. Pried it a bit :o
Nothing opens it.
Any help appreciated!
Otherwise, seem to have a similar problem opening the glove box. Sometimes it opens; sometimes it doesn't. Do I just need to replace something or tighten something?
Michael
The glove box is a known issue, it will fail shortly. The part, because it was a supplier defect, is very cheap, I think mine was $12 and you should see what you get its quite large.
I would recommend getting the part and changeing it now since to do it once its actually failed is a PIA
Have not hear of the center console problem but I think it could jam if it was slammed shut on some paper or the like
Nothing opens it.
Michael
