It should work just fine. You will just need to get the Porsche P/N pigtail cable that connects the mirror to the fuse panel and reverse signal lead. It is about $12.
Thanks for the reply, Orient Express. When you said "It should work just fine", are you referring to my first find (the mirror) or second find (the adaptor) on Ebay?
The Tequipment mirror fits the non dimming porsche mount without modification. However the M265 factory dimming option has a larger mounting base with a hole in the middle for the factory rain sensor. I ultimately had to get the windshield mount from a wreck after purchasing an NOS "dimming porsche mirror" that turned out to be the factory option version with the larger base. This will not fit the mount for the stock non dimming mirror like the Tequipment version does. This base slide onto the windshield mount as opposed to twisting onto the windshield mount. Also I wrote to the ebay seller you mentioned to ask what mount/size his mirror had but did not receive a reply. I was interested since I can't seem to get 12V power from my interior mirror to my exterior dimming mirror & am thinking that the mirror internal circuits are not allowing the + connection when the sensor tells the interior mirror to dim. Hope this helps. Bottom line- verify the mount before purchasing. BTW the power connection cost me $85 from Sunset. It is a five wire connection for both the interior & exterior mirror.
