I have read on various forums that 04 Cayennes were prone to failure of the center driveshaft bearing. When were these shafts changed and how would I know if I have one of the failure prone shafts. My CS is an 06 model but it was manufactured the first day of 05 so it has at least some 04 parts in it. For instance the ignition coils were -01 units and were just replaced under warranty with -05 units per the TSB (one coil failed TSB said to replace them all).
