Hello,
First time poster long time troll.
I bought a 2001 boxster from a friend and was looking to smooth the top motion a little; is there a lube that anyone can recommend to do so? I'd like to lube the piece of the body that lifts up as well as any joints I can.
Thanks in advance!
Nate
If the top motion isn't smooth, it's possible the rubber bushing at the connection between the push rods and the rotating wheel have worn out. I have a 2001 Boxster and noticed that the top would sort of bounce around a little as it went up and down. Replacing those eliminated the play and made things a lot smoother. I also used a little spray silicon lubricant, but I'm not an expert on the best type to use there.
Here's a link to those bushings.
http://www.pelicanparts.com/cgi-bin/smart/...20%281997-04%29
and so you know where to look, here's a link to the push rod. the bushing fits into that open metal loop at the end. There's one on the left and the right, under the clam shell. The original push rods have red plastic caps.
Edited by secretagent214
