Console Spring
Here is how you replace the spring in the center console on a 2006 997S. The cost of the part was 87 cents. Here is a picture of the part. You remove eight torx screws to get the cover off. This is the cover off. Here is the cover. There were two different length screws but it does not matter where they go. Next you release tension on the spring. I have a torx socket resting on the spring release. The last step is to pull the hinge pin out. I used a vice grip and it worked real nice
This is the support topic for the DIY Tutorial Console Spring. Please post here if you have any questions or feedback.
Thanks for the instructions, where did you get the spring from?
