I noticed that on my 993TT my driver’s side door stop was moving and I was getting a clicking sound (from inside the door). On line I found a “repair” for the clicking but no mention of the door stop moving. The passenger side makes no clicking sounds and the door stop does not move at all.
Picture: post-11869-1258221242_thumb.jpg
Questions: Is the movement normal? After I fix the clicking, how do I tighten the door stop? How is the door stop held in place? Can I get access to it from the inside of the car by removing the lower panels under the dash? Any BTDTs?
Mark near Chicago
the weld has broken that holds the door stop, it need to be rewelded
easiest way is from the door jam, a good welder can keep it looking ok
then the door jam needs to be repainted, I would find some one in your area that has done it before
