I have a 2002 C4S with electric seats. Every time I move the drivers seat, it makes a nasty grinding sound. I'm sure it just needs to be lubed. What is the correct type of lubricant to use and how do I do it?
My passenger was doing the same-I used a can of spray silicone and a towel to keep it where it needed to be and worked great!
White lithium grease in an aerosol is easy to apply and long lasting.
If you want to keep dust/dirt from sticking to the lube, try Dupont Krytox. A little pricey, but effective.
Regards, Maurice.
