My '04 Boxster w/tip makes a whistling sound starting at about 1800 rpms. Must be at a steady speed and it is continuous until you let off the gas and it stops instantly when the rpms drop below 1800. Any ideas?
More info required.
Does the "whistle" continue throughout the revs range if held at a steady speed?
Is it affected by temperature - only when cold or only when hot?
Does it stop when accelerating hard?
