2003 C4S 1 owner,no accidents,25000 miles
posted on this a while back,have a noise when driving coming from the drivers front wheel area,sounds like a coffe pot perking fast,cahanged tires,wheel bearings,front diff oil,check the whole front end,nothing loose,the noise is less when i go from a rougher road to a smooth road but still there,please any ideas this is driving me crazy and tough on the pocket
Is the noise affected by road speed,temperature or loaded by turning the steering wheel when traveling at speed?
not effected by steering,seems worse at higher speed,temperature dont seem to matter,its not as bad on a smooth new road
this is probably not the same problem, but I thought I would share it anyway. I had a very similar sound occuring in the same conditions. Turns out that side's front head light was out also because the vertical socket housing had broken at it's base, letting the light become unplugged and the cord and broken plastic to "bounce around" at high speeds and making the noise.
