Headers Install
I've been planning to install B&B headers on my '97 Boxster for some time. ALL the bolts looked very rusty and the bolts holding the exhaust manifold to the front of the catalytic converter were in very sad shape. I wasn't too concerned about the latter because I knew I could cut them off with a cut-off wheel, etc... The manifold to cylinder head bolts are another story... For the last month or so, I've been soaking the 6 exhaust manifold bolts on each side with PB Blaster and WD-40 e
Edited by 1schoir
I would use a good bolt to mark the length on my drill bit and keep drilling them out with larger and larger bits then rethread the holes. Sometimes the bolt your drilling out will just crumble and come out halfway through the process if you're lucky.
Have the vehicle towed to a shop that can use weld to shrink the remainder of the stud while some of it is still sticking out of the cylinder head. It's an old trick where you MIG or Stick weld a nut onto the broken stud and as it cools it shrinks the stud slightly and then they turn right out.
Do you think the same effect could be had by heating the remaining part of the stud cherry red hot and then trying to remove it?
My friend (who owns a service station) has an electronic tool that heats bolts cherry red in less than a minute and I was wondering if that would help?
Regards, Maurice.
Each time you heat the stud it changes it temper and it becomes brittle and you risk causing more damage or other problems. If you find an experienced welder or mill wright, he should have no problems removing the broken pieces.
you are lucky you got your starter holes centered:-) i'm never that good"-(
try JeTexas's idea with this twist.
some of the machine supply shops like MSC and local supply stores sell lefthand drill bits, (they cut in the opposite direction). Your's sound like they may be to solid to pop loose but you might try it.
get a set of the sizes you would use the drill out the stud in steps.
Drill all the way thru the stud, have some modeling clay handy, squirt the lube up in and plug the hole for a day or 2.
Then use the reverse bits to start drilling out the stud. if the bit does bind in the stud it may pop the stud loose. buy extra's i usually break one or two.
Good luck and let know what works best.
Lance
Lance
Lance:
Quite an ingenious idea with the modeling clay as a twist! I'll definitely give that method a try, in addition to gradually increasing the drill bit size and using left hand drill bits. I just got a really good set with Cobalt extractors from my friend's machine shop.
I'll keep you posted in a couple of days.
Regards, Maurice.
Lance
Lance:
Regards, Maurice.
Maurice,
You left us hanging. How did you finally get the studs out? How does the header and exhaust sound? What increase in HP have you seen?
  msmolinski said:
Maurice,
msmolinski:
Sorry about that! The headers with the PSE exhaust sounds as sweet as you can imagine!!!
I don't know about any increase in HP, except for that magical seat-of-the-pants dyno which makes it feel like it has more HP. The sound alone is worth everything, and the looks of the exhaust from behind and of the headers from underneath is also quite special.
Here is a link to the saga, detailing what happened and what I learned: http://www.ppbb.com/phorum/read.php?19,155...140#msg-1552140
Let me know if you are considering removing your old exhaust manifold.
Regards, Maurice.
  • 11 years later...
I use extractor and a AIR DRILL it has the speed you need. And I use a dewalt battery impact to extract. Works every time ! I've become really good at this. From working on Hemi engine dodge sucks btw
Edited by Drew M
