My 98 Boxster recently had the dreaded water under the seat issue. Needless to say the alarm module was fried and was replaced. Now my remote rear trunk release does not work. Should this have been programed by the dealer ? Or should it work automatically? If I have to take it back to the dealer is there anything else I should have programed into the alarm module while I am there? Thx in advance
Thats, a good question, I've soaked my alarm thing several times. My trunk dosm't work either. I know not every mechanic knows you have to program the lights to come on when you open the door, maybe the trunk ia a similar thing.
Regards, PK
Edited by pk2
I had a problem with the trunk not opening with the remote... found a blown fuse in the fuse panel... the horn is also connected on the same circuit if i remember correctly... so if ur horn doesnt work as welll...that may be the problem
