Other then taking off a wheel and measuring the rotor to see, is there a way to tell if the brakes are 330mm or 350mm? I ask as I need to replace the pads of course.
Standard brakes on the Cayenne S were 350 mm front and 330 mm rear.
If you have optional brakes they should be noted on your option list.
Perfect....Thank You...! That was a fast response too.
I think the size as well as the min. thickness is stamped on the rotor hat which you can see through the rim spokes.
Thanks. I'll go check right now...
