Is the procedure to (temporarily) remove the soft top in order to install the spinlocks on a 987 something that can be done without risking disaster?
(The goal is to temporarily remove/disconnect just enough of the top to get clearance to allow the spinlock bolts to be installed.)
Try search function. I know the 986 has been covered, but not sure of 987.
No need to remove 986 top. Trick is to use plastic bag (like done for dog poop) to avoid dropping parts into the abyss.
