My 99 996 Cab lugs are beginning to rust in a couple of places. I have seen this before on other cars. Outside of replacing them (functionally they are still fine) has anyone cleaned them up before. If so, how?
I'm sure that I could sand blast if that was an option but it's not. I'm looking for something that would be possible at home.
You could try naval jelly to clean the rust. Then use some anti-seize on the threads and paint the heads - but they will likely rust again in a few years.
FYI,
I just picked up some replacment lugs from Suncoast Porsche $4.10 ea.
for my 996.
Here's their contact info.
Phil Anderson
Internet Parts Sales & Marketing, Tech Assistance Specialist
877-923-1700
941-923-1700
panderson@sunsetautogroup.com
Our parts team experts are always ready to help you, either by email or toll free at 877-923-1700.
Parts Hours - Eastern Time
Monday-Friday
7:30 - 6:00
Sat, Sun Closed
(edit - removed white space - Loren)
I always get confused with this term "lugs".
Are you referring to the wheel bolts?
I thought Wheel lugs were only on earlier cars.
It is a know issue and Porsche would replace them if you still had a warranty. They came out with a revised wheel bolt.
Just paint them. Local 996 owner Gary paints them every time he removes them. He found matching silver spray paint at Oarchard Supply Hardware.
I got tired of cleaning the wheel bolts so i had the heads (not the threads) chromed. Cost about $50 for all of them at the local chrome shop. If you're not into chrome, maybe you can powdercoat them (again, just the heads). As for the threads, I just took a wire brush and brushed off the rust, i'm sure it'll be back eventually...
Jeff
