Hello All,
I have a friend with a 2000 Boxster (M96/23) and he bought a S engine (M96/21). Is it a straightforward swap or does the harness need to be hacked into? He mentioned that there is a sensor on the camshaft on one but not the other?
Sprint.
Probably not too straightforward. But check the DIYs on upgrading engines to 3.4 or larger if nothing shows for 2.7 to 3.2. Both use the DME 7.2, so maybe not too hard.
At least will need to PST/PIWIS to tell the ECU it is a 3.2.
And I believe the 2000 2.7 is M96.22?
