ok so i gave my dad my boxster before i mover over seas and he wants to replace the rims he is looking at 18x11's for the rear and the off set and lug pattern work...so my question is will a 295 width tire fit in the wheel well. The rims already have the tires on them? please help
I don't anyone has had any success fitting 11s on the rear of a Boxster; they are just too wide. You didn't mention the offset, but you would need around 45 to 48 mm...this will clear the inner strut but push the outer wheel into the fender lip (unless your car is safari style). 285s on 10s is close to the limit on a car with reasonable alignment (read camber).
